I have a big question, when you start reading a point of 20 seconds, does rechview save the average in the csv? or the first fixed position ???
Just to clarify your question:
- You are set up static on a point
- you start logging for 20 seconds in Survey mode
- you save the collection
Then, yes, what is saved is the average position of these 20 seconds.
Thank you Christian
But also that there are many ways to average.
Even your RTK settings will affect this, depending on your positioning method, kinematic or static.
Least squares is the method it should use. Next time I’m out, I’ll take a sloppy 30 second shot and see how it compares to the least squares location.
