Can anyone tell me where I can find the initial receiver position that was averaged for a particular base file. I notice it doesn’t stay in the base settings.
Thanks
Hi @plsurveying60,
Are you using RTK for the setup? You can find it in the RTK CSV file. You can see the base position used during your survey, and the rover uses this base position as a reference.
Suppose you choose the average option on your base setting. The base position is averaged automatically every time you reboot the receiver. After averaging, you can change it to manual so that it won’t be averaged automatically after the reboot.
Another way is to create a new point as a base and save it in the project. This way, you will have saved base point, and you can use it for the following work.
