Is there a way to configure any kind of authentication to the reachview web interface.
I am setting a Reach RS+ running as base and connected to a Wifi to obtain RTK corrections. Others users are working in this network and I would like to set some basic authentication to access to the Reach View interface to avoid “accidental” changes of the configurartion.
Is there a way to achieve this? Thanks for any help or advice.
Regards
Enrique
Simple system report
app version: 2.18.0-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 192.168.137.121
is_added: true
is_connected: true
is_visible: false
mac_address: 28:ED:E0:D6:8E:01
security: wpa-psk
ssid: WIFIPC
uuid: b8f79668-a128-44b8-a348-6987eba27c2d
base mode:
base coordinates:
accumulation: '1'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: hintd:***@ergnss-tr.ign.es:2101/FKP3
send position to base: 'off'
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: '2.6'
frequency: 868000
output power: '6'
position output:
output1:
enabled: false
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: static
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '35'
update rate: '5'
