Can anyone kindly provide instructions or tutorials on how to connect 3G/4G USB model with Reach RS? Using hot-spot from mobile phone is not a good solution because the phone will be very hot and battery comes low very quickly. Thank you so much in advance.
This version added cdc and rndis ethernet kernel modules for Linux. We don’t really support PPP. If ifconfig does not create a new interface automatically after the modem is powered up, it will need some debugging. Please post output of dmesg - last lines after connecting the modem, ifconfig, lsusb.
Easiest way is to set your modem with a Linux laptop. If it creates a new network interface(via cdc_ether or rndis) and no additional setup needed(like activating your data), you are good.
