Hi Johannes,
Could you please post the screenshot demonstrating the behavior and the Simple System Report from the unit?
All Reach devices will have the same firmware version. The future firmware updates should be released for all Reach models.
Hi Johannes,
app version: 2.18.0-r0
'wifi_status, interface: wlan0':
- wifi_mode: wpa_supplicant
- ip: 192.168.178.23
is_connected: true
mac_address: 90:b6:86:05:77:2d
ssid: WannaBeImpact2
base mode:
base coordinates:
accumulation: '0.3'
antenna offset:
east: '0'
north: '0'
up: '0.5'
coordinates:
- '52.3641923783'
- '4.87147226459'
- '51.4'
format: llh
mode: manual
output:
enabled: true
format: rtcm3
path: ntrips://:BETATEST@rtk2go.com:2101/villagename#rtcm3
type: ntrips
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1008':
enabled: false
frequency: '1'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: false
frequency: '0.1'
'1020':
enabled: false
frequency: '0.1'
'1097':
enabled: true
frequency: '0.1'
'1107':
enabled: false
frequency: '5'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
gps:
enabled: false
frequency: '1'
qzss:
enabled: false
frequency: '1'
bluetooth:
discoverable: true
enabled: true
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: jeberenz:***@euref-ip.net:2101/IJMU00NLD0
send position to base: 'off'
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: false
version: null
correction:
format: RTCM3
started: false
version: null
interval: 24
overwrite: true
raw:
format: RINEX
started: false
version: '3.03'
solution:
format: LLH
started: false
version: null
lora:
air rate: '9.11'
frequency: 868000
output power: '20'
position output:
output1:
enabled: true
format: nmea
path: :7050
type: tcpsvr
output2:
enabled: false
format: llh
path: :2013
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: '0.8'
max vertical acceleration: '0.8'
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '30'
update rate: '5'
Hi Johannes,
Sorry for the delayed reply.
Have you already tried using another Wi-Fi network (for example, you phone hotspot) to update the device?
May I ask you to send me the Full System report in PM so I can check if your unit is connected to the Internet?
Dear Tatiana, no I did not.
I just used our office wifi. The RS2 did update through the same network at that time though.
I’m traveling now (showcasing our system + RS2 in Westafrica ), so I will send a report when I’m back.
Hi Johannes,
Keep us posted.
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
