5 posts were split to a new topic: Reach RS+ satellite reception issue
Mostly correct. We do not know the true geographic location of the geophone sensors, but we know their spacing, order and relative position to features observed in the field (trees, roads, buildings ect).
Not exactly. The spacing between the geophones is known, as we put down a tape measure to ensure they are evenly distributed. We have field notes and pictures that detail the order of the geophone stations. However the geographic location of the geophones is NOT known, which is why we are surveying them with GNSS.
Again mostly correct. When I load either the raw .LLH or the PPK .POS file into QGIS I notice that the cluster of points associated with the Survey CSV point have significant time differences. The Survey CSV start and end times, for any recorded point, always seems to lag behind the associated points in the .LLH or PPK .POS result.
Incorrect. The PPK .POS result which contains ALL points from the raw log is in the correct position. It is when I use the Survey CSV points Start and End times (for a certain geophone station label) to extract a geographic location (XYZ point) from the PPK .POS file that I get incorrect results. In this case because the times from the Survey CSV are incorrect, the wrong XYZ point is extracted from the PPK .POS result.
Correct.
Incorrect. The geographic position of the Survey CSV point aligns with the raw LLH log, only the Survey CSV collection start and end times are misaligned.
Hopefully this clears things up a bit.
@polina.buriak Hereās the most definitive evidence for the time shift to date. Yesterday I was in the field doing an RTK survey with the RS2 base and rover. I decided to check the UTC start and end time for the points I had just collected and noticed this:
Iām in the Pacific time zone, so PST = UTC - 8. Given that info the reported collection time from the Survey app would put time of collection at 0751. I can say with 100% certainty that I was not collecting field data until 1100, which is 1700 UTC.
Hi Chris,
Thank you for the detailed comments on my message!
Regarding the issue with the start and end time of the point collection, Iāll try to repeat this issue. Have you had a chance to notice how often this happens with the Survey Project points?
Let me ask you a couple of questions regarding your comments as well.
Would you mind explaining how you associate the cluster of points in the .LLH log with the point of the Survey Project?
You state that they have a significant time difference so you donāt use the time of the start and of the end of the collection. Do I understand correctly that you determine the same points by how close they are to each other?
May I ask you if you average the coordinates extracted from the .POS file?
You described the PPK workflow you use a few messages above. As I see it, from the PPK result you only extract one line - that refers to the measurement started at ātotal UTC time + 5 secā.
You donāt mention if you create a special column for the ātotal end timeā column so that you could find the end of point collection to average the values.
I determine this visually. You can see in my post above on Oct 26th I show that the Survey CSV points coincide with clusters of points from the raw LLH log. These clusters of raw points occur when the operator stops to perform an observation at the desired geophone station.
I donāt average the points, I simply extract a single point from within the Collection Start to Collection End time frame.
My field crew noticed the problem occurring again this morning. When the operator turned on data logging it was noticed that the time stamp in the file name is incorrect:
The correct UTC time should have been 15:35. We have noticed this happening consistently (> 50% of the time). Whenever we observe the time mis-alignment, the time stamp on the raw file names and the time stamps in the Survey CSV file are incorrect.
Also we have noticed this only happens with one receiver (Rover), and hasnāt been observed occurring on the Base unit. Perhaps the receiver is faulty?
The field operator rebooted the receiver which fixed the problem. We cannot seem to make the issue occur, so it seems to happen randomly. I had him generate a system report that I will send to you.
Hi Chris,
Thanks for the system report!
May I ask you to reflash the unit with time issues? You can use this guide to learn how to perform the reflashing.
Please keep us updated on the results.
Hi Chris,
How is it going?
Have you had the chance to reflash the unit according to this guide and check if the issue persists?
I flashed the rover back to v2.20.8 but havenāt had a chance to tested yet. Iāll update when I get a chance to do further tests.
