when setting up a project on reachview 3. On windows 10 it gives the opportunity to select auto-save points.
In ios reachview 3 does not give that same opportunity, tried with both my phone and ipad?
using Reachview 3 version 6.9
We provide an option to configure auto-save rules in our web-based Reach Panel app. This app is a bit different than ReachView 3.
ReachView 3 doesn’t have such a feature. At the moment, it just allows configuring averaging time for the point in the Survey tab. And there is also a toggle to collect the point when you have a Fix only.
By the way, I can’t help but ask: why do you need this option? Is it for a specific project?
I guess the document was not clear for me. under “Creating New Project” the first bullet says " Go to reach-rover with a browser or the Reach Panel mobile app" I took that to mean Reachview3 ?
So does averaging apply with the fix button on or not?
I guess I first looked at the survey module in a browser and then when in field the mobile app was different
Averaging time shows the period of collecting the point. Initially, it doesn’t relate to the solution status. However, if you toggle “Fix only”, the timer will continue counting if the rover has a Fix only. Here is also a good video guide on collecting the point in ReachView 3.
Yes I have watched those videos. It was just a little confusing seeing one thing in the office and then seeing something that was not the same in the field.
I have done a project now and it worked well.
Thanks
