Hi guys,
We take into account all your requests! Thanks again for the detailed explanations. It indeed helps to understand what is needed and why it’s needed.
Also, we have an idea of a workflow you can try for now with our new Base Shift feature:
- Add your benchmark in local coordinates to the project
- Set base and configure it using an Average single
- Collect your benchmark with a rover
- Apply a Base Shift
As a result, you will use your benchmark local coordinates without its transformation to LLH format.
I know that it sounds more like a workaround, but why don’t you give it a go?
