Also, I finally managed to get it to save points without averaging. It’s not how I work however, so this isn’t an acceptable workaround, but it did save them.
Same issue for me. I have to turn off averaging to get it to take points. Sometimes it will start moving a progress bar across the bottom if averaging is enabled, but I have never had it make it to my 5 seconds setting so I just have to accept the point.
I didn’t used to have this issue. I am thinking it started happening sometime either a release before switching to 26 or right at the 26 betas and 26 release. Also, stakeouts update really slow. I can move the rover, and then have to wait for a few seconds or more for it to even update. It never used to do this either.
M2 v26 RV3 on Android 11. The M2 connects to my phones hotspot and then I connect through RV3 app.
It currently shows 5.10, but from what I see on google play, the app was updated on there a couple days ago. Because of this, I may have been using the previous version when the issues occurred since I have not done any measuring in the last few days and my phone is set to auto update apps.
The latest ReachView 3 version is 5.9 for iOS and 5.10 for Android.
We couldn’t reproduce averaging issues on 26 firmware. If you face the issue again with ReachView 3, please check if you can average points in Reach Panel. You can open it in any browser by Reach’s IP. It will help us to localize the issue.
I had a vaguely similar issue on my M+ during a field day (fw 26.1, RV3 v 6.0), with Averaging time set to 5 seconds : I would click Measure, it would take 3-4 seconds to start measuring, then every “second” of the progress bar takes around 2 seconds. I even saw the counter go backwards from 0:03 to 0:02, then 0:03, 4, 5. TOtal time to measure a point was sometimes almost 15 seconds ! And I did not have “wait for FIX” enabled.
Is this related or something different entirely ?
We will need some additional details from you to check what might be wrong. Could you please check if the points can be averaged fine in Reach Panel? You can open the web interface in a browser by Reach’s IP.
Hi Kseniia, I have set a reminder to try your suggestions next time I assemble my gear. If reach-panel works, I will also try RV 2 . I should be able to do this in 2 weeks.
Thanks!
