Wish for:
a- Horizontal and vertical tolerance FIXED values set by user at 95% confidence interval
b- Importing geoid model subgrids in .ggf format
c- Import and export RINEX version 3.05 supported
d.- STATIC session tab with 15s and 30s epoch logging rates, starting time and duration (0 to 24hr) with automatically ending session and repeating dates with autoshut off/start
e.- Seriously improvements in pairing and connecting RS2 wifi and Bluetooth when several wifi/BT devices are within range
May I ask you to elaborate on why you need to import RINEX logs to ReachView 3? Also, could you please clarify whether you face any difficulties using Wi-Fi and Bluetooth connections? If so, please describe your workflow and tell me the firmware version used. It will help me check what might be wrong.
Point Stake out mode: A possibility that ReachView automatically always chooses the nearest point of the actual project. It would be a very nice feature, thanks!
Importing a control point file would allow to bring its residuals instead of manually input just the coordinates lat,lon,height or XYZ cartesian or UTM NEE
