I have 915mhz off brand radios rover is UART 38400 and Base is USB-To-OTG 38400, this and works fine in Reach Image 1.2 app 0.49 but When I flash to 2.1 app 2.1.5 beta the the radio modules connect (steady green light) and base also has flashing red For transmitting data. but correction don’t show up if I switch to tcp then I can get the correction to show but this will not work in the field. Any help is welcome.
Edit: Found it, My position Output was defaulted on in the rover this stop the correction input.
