I finally got the Green light on, not sure how. I was attempting to re flash on windows, waited to boot the reach until the windows program began searching for it. Donāt know why it worked the last time, I had tried the same thing a seemed like a hundred times before. Lucky timing on my part I guess.
I got what I was looking for today, (My first RTN fix with one reach set up as base at my office and the reach Iāve been having trouble with as a rover getting corrections over NTRIP. worked great!
Going to start back trying to ssh into the reach unit again now, I just want to know what Iām doing wrong. Heres the output you requested. ( sorry, I couldnāt locate the file my /var/log didnāt have a folder syslog)
mwfoshee@mwfoshee-Inspiron-3521:~$ sudo tail -f /var/log/syslog | tee my_ubuntu_system_log-ReachUSB.txt
[sudo] password for mwfoshee:
May 2 20:05:45 mwfoshee-Inspiron-3521 dhclient[3116]: receive_packet failed on enp0s20u1: Network is down
May 2 20:05:45 mwfoshee-Inspiron-3521 avahi-daemon[891]: Withdrawing address record for fe80::8c6c:7da7:7d91:7c3e on enp0s20u1.
May 2 20:05:45 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773545.3335] device (enp0s20u1): state change: ip-config -> unmanaged (reason āremovedā) [70 10 36]
May 2 20:05:45 mwfoshee-Inspiron-3521 ModemManager[812]: (net/enp0s20u1): released by modem /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1
May 2 20:05:45 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773545.3517] dhcp4 (enp0s20u1): canceled DHCP transaction, DHCP client pid 3116
May 2 20:05:45 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773545.3517] dhcp4 (enp0s20u1): state changed unknown -> done
May 2 20:05:45 mwfoshee-Inspiron-3521 ModemManager[812]: (tty/ttyACM0): released by modem /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1
May 2 20:05:45 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773545.4838] platform-linux: do-change-link[3]: failure changing link: failure 19 (No such device)
May 2 20:05:45 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773545.4838] device (enp0s20u1): failed to disable userspace IPv6LL address handling
May 2 20:05:45 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773545.4842] devices removed (path: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/net/enp0s20u1, iface: enp0s20u1)
May 2 20:06:35 mwfoshee-Inspiron-3521 kernel: [ 262.191940] usb 3-2: new high-speed USB device number 3 using xhci_hcd
May 2 20:06:35 mwfoshee-Inspiron-3521 kernel: [ 262.389278] usb 3-2: New USB device found, idVendor=8086, idProduct=e005
May 2 20:06:35 mwfoshee-Inspiron-3521 kernel: [ 262.389289] usb 3-2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
May 2 20:06:35 mwfoshee-Inspiron-3521 kernel: [ 262.389294] usb 3-2: Product: MERRIFIELD
May 2 20:06:35 mwfoshee-Inspiron-3521 kernel: [ 262.389299] usb 3-2: Manufacturer: INTEL
May 2 20:06:35 mwfoshee-Inspiron-3521 kernel: [ 262.389304] usb 3-2: SerialNumber: E1840C88398CE3E6AD76A05C1E54263F
May 2 20:06:35 mwfoshee-Inspiron-3521 mtp-probe: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2"
May 2 20:06:35 mwfoshee-Inspiron-3521 mtp-probe: bus: 3, device: 3 was not an MTP device
May 2 20:06:44 mwfoshee-Inspiron-3521 kernel: [ 271.298182] usb 3-2: USB disconnect, device number 3
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.177275] usb 3-2: new high-speed USB device number 4 using xhci_hcd
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.374599] usb 3-2: New USB device found, idVendor=8086, idProduct=e005
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.374610] usb 3-2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.374615] usb 3-2: Product: MERRIFIELD
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.374620] usb 3-2: Manufacturer: INTEL
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.374624] usb 3-2: SerialNumber: E1840C88398CE3E6AD76A05C1E54263F
May 2 20:06:45 mwfoshee-Inspiron-3521 mtp-probe: checking bus 3, device 4: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2"
May 2 20:06:45 mwfoshee-Inspiron-3521 kernel: [ 272.380786] usb 3-2: USB disconnect, device number 4
May 2 20:06:46 mwfoshee-Inspiron-3521 mtp-probe: bus: 3, device: 4 was not an MTP device
May 2 20:06:48 mwfoshee-Inspiron-3521 kernel: [ 274.961628] usb 3-2: new high-speed USB device number 5 using xhci_hcd
May 2 20:06:48 mwfoshee-Inspiron-3521 kernel: [ 275.090562] usb 3-2: New USB device found, idVendor=8087, idProduct=0a99
May 2 20:06:48 mwfoshee-Inspiron-3521 kernel: [ 275.090571] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 2 20:06:48 mwfoshee-Inspiron-3521 kernel: [ 275.090576] usb 3-2: Product: USB download gadget
May 2 20:06:48 mwfoshee-Inspiron-3521 kernel: [ 275.090579] usb 3-2: Manufacturer: Intel
May 2 20:06:48 mwfoshee-Inspiron-3521 mtp-probe: checking bus 3, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2"
May 2 20:06:48 mwfoshee-Inspiron-3521 mtp-probe: bus: 3, device: 5 was not an MTP device
May 2 20:06:48 mwfoshee-Inspiron-3521 org.freedesktop.fwupd[826]: (fwupd:2302): As-CRITICAL **: as_store_get_app_by_provide: assertion āvalue != NULLā failed
May 2 20:06:51 mwfoshee-Inspiron-3521 kernel: [ 277.647307] usb 3-2: USB disconnect, device number 5
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.586863] usb 3-2: new high-speed USB device number 6 using xhci_hcd
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.716131] usb 3-2: New USB device found, idVendor=8087, idProduct=0a9e
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.716139] usb 3-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.716143] usb 3-2: Product: Edison
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.716147] usb 3-2: Manufacturer: Intel
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.716150] usb 3-2: SerialNumber: 8a6a5a05b709bde2ea7cf5a0e343d0d2
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.718295] rndis_host 3-2:1.0 usb0: register ārndis_hostā at usb-0000:00:14.0-2, RNDIS device, 22:ac:40:a2:7c:9c
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.718803] cdc_acm 3-2:1.2: ttyACM0: USB ACM device
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3049] device (usb0): failed to find device 9 āusb0ā with udev
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3065] manager: (usb0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/8)
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.721624] usb-storage 3-2:1.4: USB Mass Storage device detected
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.728974] scsi host7: usb-storage 3-2:1.4
May 2 20:06:58 mwfoshee-Inspiron-3521 mtp-probe: checking bus 3, device 6: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2"
May 2 20:06:58 mwfoshee-Inspiron-3521 mtp-probe: bus: 3, device: 6 was not an MTP device
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.771102] rndis_host 3-2:1.0 enp0s20u2: renamed from usb0
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3804] device (usb0): interface index 9 renamed iface from āusb0ā to 'enp0s20u2ā
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3919] devices added (path: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/net/enp0s20u2, iface: enp0s20u2)
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3919] device added (path: /sys/devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.0/net/enp0s20u2, iface: enp0s20u2): no ifupdown configuration found.
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3939] device (enp0s20u2): state change: unmanaged -> unavailable (reason āmanagedā) [10 20 2]
May 2 20:06:58 mwfoshee-Inspiron-3521 kernel: [ 284.808156] IPv6: ADDRCONF(NETDEV_UP): enp0s20u2: link is not ready
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3952] device (enp0s20u2): link connected
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3982] keyfile: add connection in-memory (76a03db3-a95d-3360-a1e4-efa8589a0e36,āWired connection 1ā)
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.3998] settings: (enp0s20u2): created default wired connection 'Wired connection 1ā
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4031] device (enp0s20u2): state change: unavailable -> disconnected (reason ānoneā) [20 30 0]
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4126] policy: auto-activating connection 'Wired connection 1ā
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4255] device (enp0s20u2): Activation: starting connection āWired connection 1ā (76a03db3-a95d-3360-a1e4-efa8589a0e36)
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4266] device (enp0s20u2): state change: disconnected -> prepare (reason ānoneā) [30 40 0]
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4286] device (enp0s20u2): state change: prepare -> config (reason ānoneā) [40 50 0]
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4301] device (enp0s20u2): state change: config -> ip-config (reason ānoneā) [50 70 0]
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4338] dhcp4 (enp0s20u2): activation: beginning transaction (timeout in 45 seconds)
May 2 20:06:58 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773618.4389] dhcp4 (enp0s20u2): dhclient started with pid 3339
May 2 20:06:58 mwfoshee-Inspiron-3521 dhclient[3339]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 3 (xid=0x262c366f)
May 2 20:06:58 mwfoshee-Inspiron-3521 colord-sane: [bjnp] create_broadcast_socket: ERROR - bind socket to local address failed - Cannot assign requested address
May 2 20:06:59 mwfoshee-Inspiron-3521 kernel: [ 285.728828] scsi 7:0:0:0: Direct-Access Linux File-CD Gadget 0310 PQ: 0 ANSI: 2
May 2 20:06:59 mwfoshee-Inspiron-3521 kernel: [ 285.730727] sd 7:0:0:0: Attached scsi generic sg2 type 0
May 2 20:06:59 mwfoshee-Inspiron-3521 kernel: [ 285.785015] sd 7:0:0:0: [sdb] Attached SCSI removable disk
May 2 20:06:59 mwfoshee-Inspiron-3521 avahi-daemon[891]: Joining mDNS multicast group on interface enp0s20u2.IPv6 with address fe80::2b85:eadd:c540:99fe.
May 2 20:06:59 mwfoshee-Inspiron-3521 avahi-daemon[891]: New relevant interface enp0s20u2.IPv6 for mDNS.
May 2 20:06:59 mwfoshee-Inspiron-3521 avahi-daemon[891]: Registering new address record for fe80::2b85:eadd:c540:99fe on enp0s20u2..
May 2 20:07:01 mwfoshee-Inspiron-3521 dhclient[3339]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 7 (xid=0x262c366f)
May 2 20:07:08 mwfoshee-Inspiron-3521 dhclient[3339]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 7 (xid=0x262c366f)
May 2 20:07:15 mwfoshee-Inspiron-3521 dhclient[3339]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 11 (xid=0x262c366f)
May 2 20:07:24 mwfoshee-Inspiron-3521 ModemManager[812]: Creating modem with plugin āGenericā and ā2ā ports
May 2 20:07:24 mwfoshee-Inspiron-3521 ModemManager[812]: Could not grab port (tty/ttyACM0): 'Cannot add port ātty/ttyACM0ā, unhandled serial typeā
May 2 20:07:24 mwfoshee-Inspiron-3521 ModemManager[812]: Couldnāt create modem for device at ā/sys/devices/pci0000:00/0000:00:14.0/usb3/3-2ā: Failed to find primary AT port
May 2 20:07:26 mwfoshee-Inspiron-3521 dhclient[3339]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 12 (xid=0x262c366f)
May 2 20:07:38 mwfoshee-Inspiron-3521 dhclient[3339]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 15 (xid=0x262c366f)
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.6392] dhcp4 (enp0s20u2): request timed out
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.6393] dhcp4 (enp0s20u2): state changed unknown -> timeout
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.6562] dhcp4 (enp0s20u2): canceled DHCP transaction, DHCP client pid 3339
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.6570] dhcp4 (enp0s20u2): state changed timeout -> done
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.6585] device (enp0s20u2): state change: ip-config -> failed (reason āip-config-unavailableā) [70 120 5]
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.6605] device (enp0s20u2): Activation: failed for connection 'Wired connection 1ā
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7052] device (enp0s20u2): state change: failed -> disconnected (reason ānoneā) [120 30 0]
May 2 20:07:43 mwfoshee-Inspiron-3521 avahi-daemon[891]: Withdrawing address record for fe80::2b85:eadd:c540:99fe on enp0s20u2.
May 2 20:07:43 mwfoshee-Inspiron-3521 avahi-daemon[891]: Leaving mDNS multicast group on interface enp0s20u2.IPv6 with address fe80::2b85:eadd:c540:99fe.
May 2 20:07:43 mwfoshee-Inspiron-3521 avahi-daemon[891]: Interface enp0s20u2.IPv6 no longer relevant for mDNS.
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7148] policy: auto-activating connection 'Wired connection 1ā
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7202] device (enp0s20u2): Activation: starting connection āWired connection 1ā (76a03db3-a95d-3360-a1e4-efa8589a0e36)
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7218] device (enp0s20u2): state change: disconnected -> prepare (reason ānoneā) [30 40 0]
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7231] device (enp0s20u2): state change: prepare -> config (reason ānoneā) [40 50 0]
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7242] device (enp0s20u2): state change: config -> ip-config (reason ānoneā) [50 70 0]
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7285] dhcp4 (enp0s20u2): activation: beginning transaction (timeout in 45 seconds)
May 2 20:07:43 mwfoshee-Inspiron-3521 NetworkManager[889]: [1493773663.7309] dhcp4 (enp0s20u2): dhclient started with pid 3384
May 2 20:07:43 mwfoshee-Inspiron-3521 dhclient[3384]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 3 (xid=0x3f1cb4e)
May 2 20:07:45 mwfoshee-Inspiron-3521 avahi-daemon[891]: Joining mDNS multicast group on interface enp0s20u2.IPv6 with address fe80::2b85:eadd:c540:99fe.
May 2 20:07:45 mwfoshee-Inspiron-3521 avahi-daemon[891]: New relevant interface enp0s20u2.IPv6 for mDNS.
May 2 20:07:45 mwfoshee-Inspiron-3521 avahi-daemon[891]: Registering new address record for fe80::2b85:eadd:c540:99fe on enp0s20u2..
May 2 20:07:46 mwfoshee-Inspiron-3521 dhclient[3384]: DHCPDISCOVER on enp0s20u2 to 255.255.255.255 port 67 interval 7 (xid=0x3f1cb4e)
^C
