Hy Igor
sorry but probably my knowledge of wifi configuration is to poor (I’m not able to use the reach app) so is it possible to use the reach module connect via usb to laptop with rtklib software ? I have a le6t moduloe and I can collect the rtk data with public ntrip using rtklib.
can you hlep me ? thx
The easiest way to use Reach is via the ReachView App. If you are having difficulties setting up wi-fi connection we will gladly help you. Ask any questions. Have you tried following the quick start guide?
Ciao Igor
Sorry but I’m little bit disperate …
I am to see the wifi murata on my smartphone but when I try to open the web page with the IP address
I didn’t receive any result
web page blocked no app visible
The edison setup page but at the end of the porcess I received the messase sorry reach not reachble… an d also if I see the hot spot I’m not able to open the app webpage …
ok
Now little question about post processing with rtklib
I try to use the log file with rtkconv but no result so no post processing with rinex from base station
Is it the log in a special format ? or I have to save the raw data ?
