Hello!!
I can’t open the menu to import
V 2.20.4
I think the image is damaged I suggest you to download a file again and if possible use another computer.
Thank you very much
Best Regards
Federico
What version Android does the Samsung have? ReachView app may not work with older Android versions? Does it work it using Chrome browser?
Hi Tim ! J7
You may need to go into SETTINGS > ABOUT PHONE > SOFTWARE INFORMATION > ANDROID VERSION
i.e. Android 8?
I do not know what the minimum Android version ReachView app supports?
The version is 6.01, it doesn’t work just that function.
In RS + it works well.
Supports from version 5
Hi Federico,
To update Reach, you should connect it to the network with available Internet access. After that, ReachView will automatically find a new available version and show you a notification.
Muchas Gracias , lo actualice a la v2.20.7 y se soluciono el problema, yo uso un Ipad mini4
Muchas Gracias !!!
