Hi Olivia,
As far as I can see, the new CSV file is shown correctly in QGIS:
Could you please clarify whether you’ve uploaded the file to QGIS as delimited text? I’d suggest trying the following settings:
Hi Olivia,
Hi Olivia,
May I ask you to change the X field and Y field to Easting and Northing, respectively, and check if it helps? Also, please mark the comma as a decimal separator.
@BioGis What version of QGIS are you using? There were a few versions where the PROJ libraries were completely broken and managing projections was hell. I’m guessing you’re working with an older version as the CSV import panel looks dated.
oh, wow, thank you very much - that did the trick. I never hat this issue before, but good to know this solution
Hi Gabriel, I am using QGis version 3.4.4 - that is not the newest version, I know, but also not that outdated… I also did not know that there were issues with CRS - thank you for this info.
