Can I ask you to do a firmware reflash by following this tutorial?
Let me know about the result, please.
Yes, I brushed the firmware many times, using the reachimage_v2.16.2 firmware is a failure. If the use of Reachimage_v2.1_beta firmware test1 succeeds, Test2 is failed.
Please, post here your v2.16.2 firmware reflash window output.
Also, please, check Edison connection before reflashing.
This is flash.log file.Think you.flash.log (12.7 KB)
Can I ask you to write your reflashing steps, please?
According to the log, it seems like there’s a mistake on one of them.
Thank you. I think it’s broken.
