I’ve successfully upgraded my reach RS using mobile hotspot and a windows laptop.
However, I’m facing difficulty in doing the same job with my reach modules. These are the following steps I did.
- Connected the antenna and usb cable to the reach module
- Given power to the module using 5v power bank/ also tried with wall mount charger also
- it started blinking and wifi hotspot has been created
- I tried to detect the ip address of the reach using Fing app
- But the ip is same 192.168.42.1 (the extension :5000 is not working for me… why??)
- Initially I have checked the already installed “ReachView” app in my android,
- Surprisingly, it didn’t detected my Reach (few minutes ago, it worked fine with my Reach RS)
- Reason for not detecting my reach module in the ReachView android app is unknown
- I opened Chrome web browser in my laptop and typed the above ip
- It got connected to the reach wifi
- Test is OK, in the Wifi tab – > I’ve entered my mobile hot spot address and saved the network (moto)
- Now, I swtiched on my mobile internet (4g) and hotspot wifi (my mobile wifi name is “moto”)
- I returned to the web browser (where I halted my setup)
- I pressed the wifi (moto) to connect. It displayed a message that “now the reach is connected to a different network. connect your device to the moto to continue”
- In my laptop’s wifi access, I saw “moto” is appearing and I selected it
- Now, I came back to the browser and saw that nothing is changing, it remained the same
- After sometime, the reach’s wifi got dissapeared
- When I refreshed the updater web page, it displayed ‘connection lost’
- According to the reach docs, our both reach module and the device (here it is laptop) should be connected to a same wifi (here it is moto)
- If I change my laptop’s connectivity to “moto”, how can I access the reach’s hotspot?? (big question)
- Why reach view android app is not showing reach modules ?? (It should support both the Reach RS and Reach, as per Google play store description)!!
- If the reach stopped its own wifi and tried to connect the common wifi (moto), how to check that whether it is still connected to my wifi or not?? Because the web updater no longer gets wifi signal from the reach when reach stops the wifi and also I change to the moto wif in my laptopi!!
- Is there any other way to stop reach other than unplugging the power?
The reach’s LED turned “Green” stable. I am facing problem with my two reach modules. Kindly help me to come out of this problem.
regards
Arun
