I can not get the Reach RX receive the FPRN NTRIP Correction,
Any one has any idea?
Best first-response is to contact the NTRIP provider. Then they can aid in troubleshooting using their caster connection logs etc
I see that your Wi-Fi is on. You may want to turn that off or ensure that you are not connected to the receiver through its Wi-Fi connection. At least with my RS2, I have found that Bluetooth ntrip can be affected if I am unintentionally connected to the rs2 over WLAN.
I have the same issue. I would say it started after updating the app on Android. Two phones with the latest version weren’t receiving corrections and still aren’t, while the third phone with an older version was receiving corrections. However, after updating the app on that third phone, it stopped working as well. So, three different devices, three different manufacturers, all running Android 14, and none of them are working.
Hi guys,
We’ve reproduced the issue, and as @dario0998 mentioned, it primarily affects Android devices. I’m really sorry for any inconvenience this may have caused. Our developers are already looking into it, and we’re making this our top priority. I’ll make sure to keep you all updated as soon as we have a fix.
Wishing you all a happy upcoming New Year, and thank you for your patience!
Hi everyone!
We’ve released a fix that should resolve the issue you’ve been experiencing with NTRIP. Could you please update Emlid Flow on your devices and give it another try? I’d love to hear how it works for you!
I have IOS 18.2.1 and the same issue, we update the EmlidFlow but the problem persists. I’ll try the NTRIPChecker to check RTCM messages from the provider and then I’ll tell you the result
Bye
Solved…my NTRIP Provider made some adjustments, and now I have NTRIP corrections in my RX through IOS and Android. It was probably a problem with the messages RTCM MSM3
Hi @cnarquitectos72,
Sorry, it was a bit quiet on our end here. Thanks a lot for keeping me updated! I’m glad to hear you can use your NTRIP now.
Thank´s Inkar, best regards
