Hello,
I mainly use the rs2+ and reach rx for drone mapping and been having some issues with accuracy and workflow using the two as a base and rover setup. The workflow that I use is a starlink as the internet service in the field connected to the rs2+, which is connected to my NTRIP provider. I then cast the NTRIP via emlid caster which I connect to with my reach rx. The first time I tried this all the points gathered with the reach rx as the rover were about 20’ high and offset. The second time, which was today all the points were about 1’ off. Normally I will collect all my GCPs using the rs2+, but I would much rather do a base and rover setup. Has anybody ran into this issue with accuracy using a similar workflow?
