I was wondering if the following scenario was possible.
Backstory
A customer in New-Zealand doesn’t have cellphone reception in his fields.
So we can’t use 3/4G to get the correction signal.
He does however have a device that gives a correction signal via RS232 (UHF radio)
Does the following work?
UHF radio (Tx) connecting to Reach (Rx)
Our processing module (Rx) connecting to Reach (Tx)
And then connecting the grounds togheter.
Example with pin numbers:
UHF radio (Tx) connecting to Reach Pin 6
UHF Radio (Ground) connecting to Reach pin 1
Our processing module (Rx) connecting to Reach pin 7
Our processing module (Ground) connecting to Reach pin 2
Power supply (12+) connecting to Reach pin 9
Power supply (ground) connecting to Reach pin 3
You can split RS232 quite successfully on RTK streams from the radio is the comms is mono-directional. That why you only need two wires Tx —> Rx and signal ground. To get corrections via radio.
The issues crop up when more than one device wants to talk.
I’d be more concerned about the power split arrangements.
