I´m new to the rs2 device and I have some inquiries related to its funcionality. Today I made some test using the static mode and saving the log files on RINEX. After downloading the data, I imported it to Magnet tools and it appeared as Kinematic. Can post-processing be made in Magnet Tools using the RINEX logs? I would also like to know what is the antena code/name to find it on Magnet Tools. At last, I would like to know what are the position, base correction and raw data logs. Thanks in advance.
Off the bat, I can’t remember where the toggle button is located in Magnet but I know that you can change the kinematic setting to static. It still uses the same rinex data but it will output to a single observation point.
Choosing Kinematic or Static mode in the ReachView 3 RTK Settings tab shouldn’t influence the raw data log. However, as far as I know, Magnet software now supports only Topcon and Sokkia receivers. So, it might cause an issue.
Reach RS2 antenna name is EML_REACH_RS2.
The position log (LLH) contains the coordinates of the Reach receiver calculated at regular intervals. You can change the interval by choosing the Update rate in the RTK Settings tab.
Raw data logs are UBX or RINEX logs that contain GNSS observables. You can process raw data logs from your rover and base together in RTKLib to determine a precise rover’s position. If you use a remote NTRIP base station, you can record the base correction log on a rover unit to get raw base data for PPK.
As a way of updating info, the post-processing was made satisfactory in Magnet Tools. Now I´ll just have to compare results with another GNSS receiver over the same BM point. Hopefully I will share results in the following days.
