Hey all! I recently purchased an RS2 survey kit to correspond with my P4 RTK.
On one of my outings I accidentally set the rover’s base mode and have been unable to remove the information. Everytime I turn the rover on it runs a single fix for corrections, I’ve tried changing it to manual, float and fix with no luck. Any suggestions?
If you don’t want your Reach to send base corrections, you can turn off Correction output in the corresponding ReachView 3 tab. Base mode just allows you to enter or average the base position and doesn’t affect your setup if there are no outcoming corrections.
