I have to connect the Emlid Reach RS2 (firmware v.2.22.7) to a GSSI Profiler EMP-400 through a TDS Recon-400 PDA with RS232 serial port (DB9M).
The Profiler is designed to accept a NMEA GGA string (i.e. $GPGGA) and the GPS system COM output format should be configured as follows: 8 bits, N (No) parity, 1 (stop bit), BAUD: 4800/9600. The message rate must be set to 1 Hz.
I have two questions:
I have bought a “Reach RS2 cable 2m with DB9 FEMALE connector”, can I directly connect the Reach RS2 output port (UART) to the TDS Recon-400 PDA RS232 serial port ? Do I have to use a UART to RS232 Converter ?
Is it possible to set the Reach RS2 to output only a NMEA GGA message? Is it possible to set a $GPGGA message instead of a $GNGGA one?
Ive pulled this off with additional hardware, But emlid is now looking into it. They are very receptive to this community forum but they have a very long to do list.
This system is always improving, but coding takes a pile of time.
I know it is possible to set the u-blox GNSS chipset to use GPS satellites only and then output a $GPGGA message (via u-center software and proprietary commands), but Emlid Reach RS2 its another story because it has its own controller and firmware in between the user and the GNSS chipset.
