In PPK mode, how to collect coordinates GCPs if using only reach M2+ and reach RS2+?
Hi Warawut,
Welcome to the forum!
Reach M2 is designed for drone surveys, and it’s not so easy to set it on a pole or tripod. Overall, we recommend our field-ready receivers for the task.
However, you can collect GCPs in PPK with RS2+ and M2. You need to enable raw data logging on both devices. After collecting logs, you can perform Stop & Go with Emlid Studio using your collected logs and CSV file from Emlid Flow to determine the coordinates of your GCPs.
