hello community
I’m trying to setup a reach rs2 for a friend and I’m failing miserably.
The rs2 has a sim card for corrections download which is working.
The latest firmware is installed (I even flashed the unit again to be sure),
also the latest reachview3 is being used.
I can connect to the units hotspot, corrections are being downloaded and I get a fix.
But the wifi connection to the unit drops after a few minutes and even though I can
sometimes reconnect the wifi, I’m not able at all to reconnect within reachview.
the unit is simply not visible anymore. the only thing I can do is restart the unit and begin again. also, the connection within the webbrowser doesn’t work anymore either.
it seems to be there is a problem with maybe IP allocation maybe internal vs. WIFI), but I’m not sure. I have the impression that without internet sharing, the connection holds.
I also had some wifi connection drops with my reach rs+, but never this bad.
Like this the unit is absolutely not useable. The only thing I could do is use a seperate
hotspot, which is kind of not the point.
Is there anything I can do to solve these issues? I’m really at a loss here…
