Hi guys
I wanted to know if any of you have tried to connect the REACH RS2 to an external IMU.
The goal is to collect an accurate trajectory (± 50 cm) in bad conditions like city center where very often you can loose the GNSS signal.
It seems hardly possible to do so as RS2 won’t be able to use the data from IMU in its solution calculations. I know about the indoor positioning system that uses IMU, but you may need a medium device that will combine the data from the GNSS receiver and the external IMU.
