I am a new user of the RS2. I’m having trouble figuring out what default Datums (both horizontal and vertical) are used by the RS2. I can find nothing in ReachView that addresses this. I’ve used the Trimble Geo 7 for several years. I just logged a bunch of points with both the Geo7 and the RS2. I did PPK with both datasets using the same CORS station data. Horizontal coordinates are off by about a meter and vertical is off by about 16.5 m. The Geo7 is using WGS84 and I assume that the RS2 is using the same so I can’t figure out why the difference. The vertical issue looks like a vertical datum issue. The Geo7 is set to log vertical data as height above ellipsoid.
