I am not able to turn the cellular data switch on. Every time I try to flip the virtual switch the screen turns slightly grayer and doesn’t allow me to turn it on. Has anybody else had this problem. The strange thing is that it shows cellular bars and I can hotspot data to another device but it won’t get NTRIP corrections.
Have you filled in the APN field below?
Well it wouldn’t even let me put the cursor in that bar. Does it need an APN 100% of the time? I was able to connect to the internet on my device through the RS2 hotspot.
It needs the apn of your carrier, yes. Otherwise the mobile connect simply won’t work (in some rare cases it is not used/auto-detected though).
If you use the same provider for your phone, you could simply copy the apn string from your phone to your rs2.
Okay, Thankyou for your help. I will try that.
Hi Andrew,
I’ve just answered to your email with the same question. Let’s continue our conversation here.
Did @wizprod’s advise help you?
I messed with the SIM card this morning again and now it works. The apn is blank and it works fine. Thanks for your help.
Good to hear!
