Hello,
Starting today I am unable to connect to my Reach RS2 units using their onboard wifi. Every time I try to connect to the Reach RS2 units I get “authentication error” or the phone simply refuses to connect. The units worked fine last time I used them on 14 May. Both units appear on the available networks list but I can’t connect to them
Wifi LED is solid white on both of them. The phone has had no software updates. I also tried to access the ReachRS2 hotspots via my laptop and I had the same problem.
(Edit: I am now at home. I can now access the reach RS2 units both by having the phone and the reach units connected to my wifi router and I can access them directly from my phone using the Reach hotspot. Not sure why earlier at work it did not function correctly. At work, my phone is on the work wifi but the reach units are not.)
