Hello.
I have trouble connecting my Reach RS+ to my WiFi for update.
It IS a “new” model withsticker on top, but the ReachView app cant see it and say that it need to be on update. 2.8. Fine.
So i start update guide and follow it to a crum.
The problem starts when i setup wifi for reachview, it simply does not connect to it.
I tried with WPA, WPA2 and with no password,still cant connect to simple SSID “HomeBox”
Any ideas ?
I have the axact same issue and on a mobile hotspot as well , it does connect maybe one in 10 times. rs+ version 2.16.0 Im setting the rs+ up as a permanent base station so I will need it to connect to my wifi every time I turn it on
During the first time setup Reach always checks for updates. You already have the latest v2.16 installed, so it’s a normal behavior. You can reboot the device and go to the app.
If you work over LoRa, you don’t need the Internet connection any more. You can disable Wi-Fi hotspot on your mobile device and let Reach start its own hotspot.
Could you please clarify your issue with ReachView app? All settings you’ve changed over the browser version are saved on Reach, including Wi-Fi credentials.
