Hello,
We are thinking of acquiring a Reach RS to get control points with centimetric precision. At the moment we are going to buy a unit with the idea of connecting it to the GPS network through NTRIP.
The question is: can we get centimeter accuracy without a base station?
Thank you very much.
@gontz of course, you can use NTRIP instead of your own base station. You can get cm-accurate coordintaes if NTRIP base station is in close proximity (usually it is preferred to have baseline less than 10km).
Thank you @mikhail.avkhimenia
I wanted to say if its possible connect to a network of fixed gps stations and you normally access the data through a user and password.
Regards
Do you mean like this?
Link to docs:
https://docs.emlid.com/reachrs/common/reachview/correction-input/
