I have a Reach RS that was purchased in 2018 and will not start.
This device is used on tractor for guidance and is usually charged via the bottom port when the tractor was running.
When pressing start button the lights flashed and then turned off and it would not restart. I initially thought that the battery had gone flat overtime so I tried recharging via the USB port with several different usb power sources and the bottom port directly connected to a 12v
battery. The RS2 will still not start.
On opening the case I found droplets of water inside on the grey top and also in side the black body of the case. I have waited for these to dry out but it still does not start. I have tried measuring the voltage from the battery but the terminals on the plug are very small and difficult to position probes but the battery would appear to be flat now and has not held charge.
Does anybody have any experience with this situation and can recommend any diagnostic steps
to verify what the cause of the problem is.
thank you
Graham
