I decided to update my system from 2.15.5 to 2.21.1 today. I have done updates for versions previously and have not had any issues. Today, my rover’s STAT light never turned green indicating a successful update and my app never restarted. It had the screen that tells me that the version software is updating. After 3 hours of continuous wifi connection with no results to say that the version has successfully updated, I decided to try to reboot the rover myself. Now, I am stuck. My rover will only power on (only orange PWR light on). No NET or STAT lights. I have no connection with my phone app. What happened?? Can anyone direct me how to get this rover running again on the latest or previous version??
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Watch controller logging activated
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Cli arguments: Namespace(listen=‘localhost:55675’, logconfig=‘C:\Program Files (x86)\Reach Firmware Flash Tool/logconf.json’, logfile=‘C:/Users/Huot Samnang/AppData/Local/Emlid/Reach Firmware Flash Tool/logs/01.11.2019_22-14-45/watch_controller.log’, parent=1760)
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Unknown cli arguments:
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Construct WatchController
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Start grpc server
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Create process representer for parent(1760)
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Wait for terminating_event or parents’ death…
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - gRPC Start() called
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Creating watcher…
22:17:35 - services_factory.py - IP:localhost:55675 - Port:not set - INFO - OneShotNeutisWatcher created
22:17:35 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Starting server…
22:17:35 - grpc_service.py - IP:localhost:55675 - Port:not set - INFO - Check (‘127.0.0.1’, 50357) socket
22:17:35 - grpc_service.py - IP:localhost:55675 - Port:not set - INFO - Socket was picked
22:17:35 - grpc_service.py - IP:localhost:55675 - Port:not set - INFO - New channel state: ChannelConnectivity.IDLE
22:17:35 - grpc_service.py - IP:localhost:55675 - Port:not set - INFO - New channel state: ChannelConnectivity.READY
22:17:36 - grpc_service.py - IP:localhost:55675 - Port:not set - INFO - udp socket was closed
22:17:36 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Server has been started
22:17:36 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Work mode: flash
22:17:36 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Initialize Watcher
22:17:36 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Watcher has been initialized
22:17:36 - grpc_service.py - IP:localhost:55675 - Port:not set - INFO - New channel state: ChannelConnectivity.IDLE
22:17:37 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - The number of plugged devices has been changed to 0
22:17:37 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - gRPC Watch() called
22:17:37 - watch_controller.py - IP:localhost:55675 - Port:not set - INFO - Begin watching
22:17:39 - watch_controller.py - IP:localhost:55675 - Port:not set - ERROR - Catched RpcError: <_Rendezvous of RPC that terminated with:
status = StatusCode.UNAVAILABLE
details = “Connect Failed”
debug_error_string = “{“created”:”@1572621459.115000000",“description”:“Failed to create subchannel”,“file”:“src/core/ext/filters/client_channel/client_channel.cc”,“file_line”:2608,“referenced_errors”:[{“created”:“@1572621459.115000000”,“description”:“Pick Cancelled”,“file”:“src/core/ext/filters/client_channel/lb_policy/pick_first/pick_first.cc”,“file_line”:234,“referenced_errors”:[{“created”:“@1572621459.114000000”,“description”:“Connect Failed”,“file”:“src/core/ext/filters/client_channel/subchannel.cc”,“file_line”:663,“grpc_status”:14,“referenced_errors”:[{“created”:“@1572621459.114000000”,“description”:“OS Error”,“file”:“src/core/lib/iomgr/tcp_client_windows.cc”,“file_line”:106,“os_error”:“No connection could be made because the target machine actively refused it.\r\n”,“syscall”:“ConnectEx”,“wsa_error”:10061}]}]}]}"
Thank still problem. Now i found that because of USB. Some USB can not work properly with Emlid USB. I don’t know why, because i can reflash Emlid with my old PC but i can not reflash with my new PC
Yes sure I try to reflash the unit because my Emlid Reach RS+ have problem after i update to version 2.21. Now i already reflash to stable version 2.18.1
