Dear Emlid Team,
Dear Emlid Users,
I’ve been trying out the RS232 output of the Reach RS+ (v2.18.1) and I found that not all baud rates available in the settings (and specified here https://docs.emlid.com/reachrs/common/reachview/base-mode/ ) do actually work. Here is the list:
460800 - invalid
256000 - invalid
230400 - OK
153600 - invalid
128000 - invalid
115200 - OK
57600 - OK
56000 - invalid
38400 - OK
28800 - invalid
19200 - OK
14400 - invalid
9600 - OK
4800 - OK
When changing baud rates, the last valid (OK) setting was preserved and used until the next valid setting was used.
Example:
Step | Set | Actual
1 | 57600 | 57600
2 | 14400 | 57600
3 | 256000 | 57600
4 | 230400 | 230400
Did anyone else encounter such behaviour? In case this is true, will the documentation please be updated? As well as removing the invalid settings from the app?
Thanks!
PS: I checked the results with both an oscilloscope and a serial terminal on PC.
