Just received two RS+ units. So far so great.
Until we got to the job site and started setting up yesterday.
I was collecting GCP coordinates for a drone survey. About 10 minutes into the Base collecting its fix, it unexpectedly powered off. Outside temperature was 31c. Internal temp recorded as 37-40c according to battery indicator page.
After powering back on this unit keeps turning off unexpectedly. Each time the interval is shorter and shorter.
I really think there’s a hardware issue with this RS+ unit, and a thermal junction is being reached across one or many IC’s that’s tripping software/hardware shutdown mechanism.
**EDIT:
When I returned home and it was night time, I set the base up with the exact same configuration. Outside temperature was is the 18-20c range. The unit did not power off and was on for 2 hours without a problem.
Any other cases of this?
