My Reach RS+ stuck in loading mode, all orange, blue and green light blinking.
I use Zadig because on the device manager “Unknown USB device”.
Zadig for USB serial " Driver installation failed".
I use Reach Firmware Flash Tool the Reach RS+ can’t connect.
The USB cable work, USB port work, but why the Reach RS+ can’t be recognized?
My OS is Windows 10. Any idea? Thanks for helping.
Do you have enough juice on the battery?
I use win10 and it works fine. I heard some had issued with Windows Home prerelease if i recall correct. @wizprod was this your issue too?
Do I understand correctly that you’re getting issues with reflashing the device? Could you please clarify why do you want to reflash the device?
Also, may I ask you to share flasher logs so we can look into them and check what might be an issue with reflashing? To access flasher logs, you can follow these steps:
Press Win + R
The Run window should appear
Paste this string into the Run window: AppData\Local\Emlid\Reach Firmware Flash Tool\logs
