When Reach RS rover go to long distance, sometimes lost signal from base and reconnect, but no refresh coordinates reading and “age” of last reading appear with long time. Some comments for refresh reading after reconnect? Thanks.
How long range? RTK or static
Lowering bit rate might help, But its a tendency that AOD will rise of its own if using to many satellitesystems
Thanks. RTK, 3 to 5 km. I was reading 3085 m baseline when i was at 4800 m because this is old reading when losted base signal and not refresh the baseline when reconnecting to base. Testing with another equipment Trimble 5700 at the same time. I will try with lower bit rate.
