Having a hard time getting FIX position on the rover.
Have set auto-save to occur once fix is found for 5 seconds.
We are seeing time to acquire fix ranging from near-instant (one time…it was awesome!), to 15+ minutes (more common), to not at all (having given up after 30+ minutes).
In all tests thus far, rover loses connection with the base altogether occasionally, seen here:
With my limited experience, here is what have helped me obtaining a (more stable) fix:
Setting max dB power and lowering bitrate to 9.11 increased my non-line-of-sight range in urban housing areas from 250 meters to 450 meters.
disabling Glonass AR all together. This was probably what helped the most. What it does to the absolute precision, that’s a really good question.
if using Static mode, and moving the rover to a next point, in a stop and go flow, you have to enter Kinematic mode, and let it find it’s new approximate position, and then switch back to Static again. Otherwise it will only move extremely slowly towards your new point, and it will see it as a huge amount of outliers, and thus you won’t obtain a fix.
Have a good unobstructed skyview with as little potential for multipath as possible.
Hope you succeed! We are all struggling with this black magic, it seems!
