To reflashing my antennas reach rs in windows.
I unload and unzip the image (v2.14), I save it in a new folder. Now I download dfu-util.exe and libusb-1.0.dll. I put these two files in the same folder where I put the image (v2.14), is that correct?.
My doubts are; Once the intel edison driver is installed, should I place it inside the new folder along with the image and the two previously downloaded files?.
And my other question is, my antenna must be on at the moment I have to connect it to my computer ?.
Erro, you are referring to NON-PLUS versions correct? You may need to start your own “NON-PLUS” versions thread that utilize the former Edison chip… this new post may confuse things for new users of the PLUS versions?
ok, I have read the instructions in emlid docs. But I’m not clear about the intel driver section.
I downloaded the intel driver file and paste it into the folder along with the image v2.14, (do not install / run it) how it appears in the photo I uploaded, is it right to do that? or should I download it and run it independently?.
I really have not tried. I am still not sure if I am following the instructions correctly and if the reflash solves the problems.
Start by asking what can be the cause of the reachview app being frozen, showing negative age, loss of gray and orange / green bars and frozen baseline. Everything in fix and in short distances.
He clarified that they had never failed in that way, it was the second time that I used them with version 2.14, the first one made it very difficult for me to keep fix and a very low Ar. Something that did not happen with version 2.11.
Another problem I have is with the battery of one of my antennas rs.
The orange led began to flash (low battery), it had 12%. I connect to charge and in just over 10 minutes it shows that it is fully charged (100%). Even so I leave her carrying more than 3 hours. When disconnecting it; the load starts to fall very fast in 15 minutes is 70% and I prefer to turn it off.
Can the battery failure be related to the malfunction that you experience in reachview?.
Reflash can be a solution ?.
