We bought a couple of Reach RS+ units the other day. I’ve played around
with them but not really used them in anger. On Friday I put the ‘rover’ on charge, then on Saturday morning switched the unit on. I got some bizarre LED patterns before the unit ended up doing the following when plugged into USB and nothing otherwise.
Does anyone have any idea what might be the problem?
Yes the same happens when it’s plugged into the wall charger. When I remove the cable I now get no LEDs at all. I’m not able to set the device to the mode that allows you to flash the firmware.
