I have had the rover setup in the office at the moment connected to the wifi for over an hour and it has been stuck at the 99% for about 30 minutes. Any ideas/tricks to get it moving or how long I should let it run.
Firmware: 2.14.0
The UBX file for this one can be found here: Error
(shortened link to Sharepoint because I can’t upload it here) in case someone can spot something in the file.
I have tried restarting it a few times, both via the GUI and the hardware buttons. You should be able to see in the image I posted the other logs that have been generated on each restart.
The disk space has approx 3GB remaining. I can download all the other logs that were important (i.e. the UBX). I am tempted to delete the one that is at 99% and see if it does the same to the next log.
Can I ask you to retry deleting the log, then generate a full system report by following this tutorial and PM it to me.
Also, would you be so kind as to try another web browser?
PM sent with the log, and I just tried deleting the processing log in Chrome, Firefox, and via the app on iOS. the app seems to have deleted the log, but none of the other logs are processing.
Thank you for sharing reports and logs. Unfortunately, it’s still difficult to say what prevents the log from processing completion. I’d suggest to delete the log with mobile app or web browser (not IE or Edge) and start over.
Please report us if the error recurs in the future.
