Dear emlid community,
Are there any experiencies with Reach RS in cold weather around -15 degrees?
Thank you for sharing
Yes, mine still works after a night in the frigde -26C
Thank you TB_RTK for your quick answer! and Thanks emlid for the great product and support!
The idea is to take 2 Reach RS to cold areas with around -20 degrees Celsius.
Thank you for sharing your experience.
Best regards,
Well, i think it should work just fine. But i would suspect battery would perform “less” when cold and the software run a bit slower. Other then that i cant say i noticed much difference when i run mine after a night in the fridge
