We have been using a Reach RS for a couple of years now and haven’t had any issues. In the last two days, the Rover device has failed to boot, getting stuck in the update screen:
As you can see, all the initial tests are failing. There does not seem to be a cause that we can think of on our end (i.e. nothing significant has changed from existing setup).
The first time this screen happened, I setup the firmware update to 2.16, but this has not fixed the problem (the tests were failing before, and after the update).
From reading other comments here, it seems that these are hardware problems. What are the next steps, and how severe is this problem?
It is possible it was dropped - I took it home and another piece of equipment was damaged during that time (I have young kids…). I will check on this front too, but that seems a possible cause.
Does Windows detect the Reach RS as a USB device in Device Manager or see it anywhere else in the Device Manager?
Were you trying to update to lateset v2.16? Does the rover function still, but just stuck on older version? Or just dead altogether? I.e. won’t boot or nothing, or does it work at least?
Hey, I am on Ubuntu here. I do not have a Windows system that I can test on until next week.
The firmware update to 2.16 worked - the Reach is on that now. However, it won’t boot into normal operation as the tests are failing. The previous screenshot is as far as I can get.
