Dear Sir,
I have a problem with Reach RS (SN EFD61513A453FSAD1736) unit because does not turn on.
The unit worked very well until a month ago. I used it as a rover with my new Reach RS2. After a pause of few weeks, the unit does not respond.
All the frontal LEDs remain off.
I tried:
to reset the unit by pushing the button for 15 seconds;
to power the unit for a day also using different USB cables including the original;
to connect directly to the PC USB port and to use the Reach Firmware Flash tool;
the unit is many years old, could the battery be off? In this case how to replace? Can you sell me a new pack? Or I can provide myself?
Looking your news
Best regards
Marco Menichetti
Dear Svetlana,
thankyou for the reply.
Yes, the frontal LEDs remain off.
I tried all the options including point 3 of my previous message. Any reaction.
I tried different USB ports on different PC. The Reach RS doesn’t respond… seems dead.
Looking your news
Best regards
Marco
Having the same problem with both of our Reach RS units that have been sitting on the shelf for a few months. Seems like the batteries die in these units if they are not kept plugged in.
Yet it is well written in the EMLID Receiver User’s Guide in the Storage section itself recommended for all electric devices using the batteries of the same type.
As a reminder :
STORAGE
To prepare Reach RS,RS+ or RS2 for storage:
Charge the battery to at least 60%.
Turn the device off by pressing and holding the power button for 3 seconds.
Make sure that device turned off by checking that power led went out.
Store the device at room temperature.
Check the device every 3 months and charge its battery to at least 60%.
Sorry to hear that you face such an inconvenience with the device. However, since it doesn’t show any signs of life, we can hardly investigate what went wrong.
Also, we can’t provide you with a spare battery. We don’t produce spare parts, and we don’t recommend open the devices since it violates its IP67 protection. Even if you manage to repair the device, it can be easily damaged by water or dust.
