The rover shut off suddenly during a survey, I assume due to the excessive heat (104°F/40°C). I let it cool off and after restarting, it was unable to open the project or download points. I can download logs, but Survey data seems to be corrupted.
So I started a new project and repeated the survey with a new project. The second project seemed to go normally, however after I was done, I was unable to open or download the points from the second project as well. I used both the Android app and the http endpoint. The dev tools console shows no errors.
Is there a way to access at a minimum the epochs of my shots through some other means than the onboard app, such as SSH, file system, etc.?
In the future, is there a way to monitor the temperature to prevent a catastrophic failure in the field?
Firmware image and ReachView version. v 2.22.3
System report:
Simple system report
app version: 2.22.3-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 192.168.1.52
is_added: true
is_connected: true
is_visible: false
mac_address: 8C:F7:10:19:8D:88
security: wpa-psk
ssid: MySpectrumWiFicc-2G
uuid: 4f4390a1-2101-4e2b-b889-0814139825ac
base mode:
base coordinates:
accumulation: 2
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- 0
- 0
- 0
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: 1
'1006':
enabled: false
frequency: 0.10000000000000001
'1010':
enabled: true
frequency: 1
'1097':
enabled: true
frequency: 1
'1107':
enabled: true
frequency: 1
'1117':
enabled: false
frequency: 1
'1127':
enabled: false
frequency: 1
bluetooth:
discoverable: true
enabled: true
pin: '***'
constraints:
lora:
frequency:
- - 902000
- 928000
correction input:
input2:
enabled: true
format: rtcm3
path: lora
send position to base: 'off'
type: lora
input3:
enabled: false
format: RTCM3
io_type: tcpsvr
path: :9028
device: null
logging:
base:
format: RTCM3
started: true
correction:
format: null
started: null
debug: false
interval: 24
overwrite: true
raw:
format: UBX
started: true
solution:
format: LLH
started: true
lora:
air rate: 9.1099999999999994
frequency: 902000
mode: read
output power: 20
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
rtk settings:
elevation mask angle: 10
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: 1
max vertical acceleration: 1
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzss: false
sbas: false
snr mask: 35
update rate: 5
