Hi everyone,
I am trying to read RTCM3 output in RealTerm from a reach RS+ connected via serial port. The reach is in base mode and connection is set to serial with a baud rate of 115200 but all I get on the screen is junk when it should be ascii. The same baud rate is set in RealTerm.
When I try to read position output with the same parameters everything works fine. For some reason I cannot get base output to appear clearly.
Thanks for your help!
