I am trying to use the Reach RS+ as the base station in an RTK setup in QGC on a linux pc. I have configured it through ReachView to send base corrections over serial USB-to-PC and connected it accordingly. However, QGroundControl does not seem to detect its RTCM3-messages. Is the RS+ compatible with QGroundControl? If so, are there any specific settings to change in order to make it work?
Hi @mullinsen,
Do you use the Emlid version of QGC from this page?
Could you also attach photos of your base and rover hardware configuration?
