Jack_Xu
(Jack Xu)
February 4, 2018, 1:03pm
1
I want use two Reach RS via Lora survey,but now i set Rover module correction input is lora communication,the picture is my set,
and the picture shows always connect Base station ,but the reachview can’t shows base station gnss gray signal
the lora module frequency and air date rate set same,
Hello,
Please provide a system report with the settings. Does the issue perssist after a reboot. What is your solution status?
Jack_Xu
(Jack Xu)
February 14, 2018, 5:59am
3
Now i cant receive REACH RS signal at status,it not display gray pillar.
Jack_Xu
(Jack Xu)
February 14, 2018, 6:21am
4
The REACH RS have set same parameter,i can see correction input display have communication another REACH RS.
Jack_Xu
(Jack Xu)
February 14, 2018, 6:26am
5
but i cant see BASE date at status display gray pillar, and the AGE AR BASELINE column display zero.
bide
February 14, 2018, 7:28am
6
Is your base outside and receiving satellite signal?
Jack_Xu
(Jack Xu)
March 24, 2018, 9:45am
8
yes i can received satellite signal!
Jack_Xu
(Jack Xu)
April 28, 2018, 3:18am
9
hello can anyone help me?
TB_RTK
April 28, 2018, 5:45am
12
Jack_Xu
(Jack Xu)
April 28, 2018, 4:50pm
13
I have sent system report to bide,but i don’t received any answer
TB_RTK
April 28, 2018, 5:04pm
14
Well, we are on our fri time here and @bide is a busy man for sure.
Could you post it here?
If you have sensitive info on it and dont want to go public, you could send me a PM.
Jack_Xu
(Jack Xu)
April 28, 2018, 5:05pm
15
can you send me your email?
TB_RTK
April 28, 2018, 5:13pm
16
I would like you to send me an PM on this forum, if thats ok.
Link to dropbox or google disk is awesome
TB_RTK
April 29, 2018, 5:53am
18
Hi, thanks. @bide reminded me of this one. You sent me before but i could not trace this issue.
Its been forwarded to Emlid
system
(system)
Closed
August 7, 2018, 5:53am
19
