As of now, 5:16 PM May, 22 2018, I have performed a firmware reflash and update to all associated apps.
I have followed the quickstart guide to “Setting up base station” and “Setting up rover”.
I have my “Base” Reach set in Base mode to LoRa, 1000.0 MHz, 9.11 kB/s, and the correction output set to “ON”.
I have my “Rover” Reach set in Correction input ALSO to LoRa, 1000.0 MHz, 9.11 kB/s, and format RTCM3.
I have both units on my kitchen table next to my laptop and the Rover and Base are communicating.
QUESTION: When I set up the base station on a tripod, do I need to go in and do anything? Or will it automatically startup in the base mode settings I have chosen? IF SO, then all I need to do is connect to the rover and set up a new project with Float and Fix with their specific criteria to perform a survey with RTX corrected positions? I do have raw logging on in both the base and the rover to allow for the additional post processing.
Thank you for you time everyone and I apologize if this is a simple question. I was handed these units and told to get them running.
