Reach Rs as Base and Reach M+ as rover communicating correction thru radio for land survey only. not for aerial survey. what do you think?
Hi Joseph!
You can use the setup for the land survey. However, note that Reach M+ is not designed for it. So, you will need to purchase a LoRa radio module, GNSS antenna, and external power source additionally to make the setup work. Please note, that it may also be hard to mount Reach M+ with all the above-mentioned equipment on a survey pole.
as long as it works.
My M2’s work great as static. See below for homemade mount for the helical antenna. I’ve since bought antennas that are in NGS calibrated models. I keep receiver and battery in blue bag hanging from bipod.
